Injection Help =)
Old Nov 16, 2005 | 05:31 PM
FBoDyV85's Avatar
Car: 89 IROCZ Camaro
Engine: 350 w/ Boltons
Injection Help =)
I posted in TPI forums but wasn't getting any responce after bumping thread several times. Heres my question
I have an 89 camaro stock 350 TPI. I am running 3" hooker headers back w/ strait pipe, Thirdgen ram air, 24 lb ford racing injectors, stock ecu, fuel pump, and rails. Im looking into getting a nice fuel setup with full MSD ignition. Im new to the whole MSD thing. What type of setup would i need since im running bigger injectors and plan on getting better fuel rails n pump. Any information, insight and links would be greatly appreciated.
-Steve-
P.S. If i left the stock ECM then got a full MSD igntion inc. blaster coil and multispark that timed in at 2000rpm would that work out?
basically is there a way around reprogramming the ECM and using the unburned fuel to make some power?
Old Nov 16, 2005 | 05:55 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
On a stock system, an upgrade ignition to a full MSD can be argued as money better spent elsewhere.
PurelyPMD
May 5, 2016 04:57 PM
NZKnight
Oct 15, 2015 02:47 PM
racereese
Oct 10, 2015 09:39 PM
shanelique22
Sep 24, 2015 06:30 PM
