Taking out Smog Pump?
Old Nov 30, 2001 | 04:57 PM
duke_mushroom's Avatar
I just read the tech article. Is it talking about taking the whole thing out, or just re routing stuff so that it's non-functional. We just got rid of emissions testing in OK and I'd like to do whatever I can to free up space and horsepower. BTW, the smog pump is that thing right behind the AC right?
Old Nov 30, 2001 | 08:26 PM
Guest
Guest
Posts: n/a
Its actually under the AC on serpentine belt equipped cars. One of the pics in the article is mine, the entire AIR system is missing from the car. You will need some plugs for the exhaust manifolds (if you have those), dont quote me on this but I think the size I used was 1/4"NPT. Its actually 3/8"UNC, a normal straight coarse thread, but the only sort of 'plug' you will find in that size that will reach all the way is a bolt, and since the inside edge is a taper seat the bolt wont seal it off too well. Use brass plugs and they will stay in and deform nicely to prevent any leaks from the manifold. You will also need to block off the air tube to the cat, I wouldnt remove it unless you feel like going through an exercise in frustration, as it does not really get in the way of anything. That will clean things up alot, and changing plugs will become much easier.
Important point to note:
I keep hearing and seeing people break off the bolts for the smog pump, the ones that hold it in the bracket. Lots of PB Blaster or WD-40 or whatever you use might not be a bad idea, and some patience to take them out properly. Giving some solid but not real hard taps with a hammer helps free up frozen bolts, you might try that too.
[This message has been edited by madmax (edited November 30, 2001).]
Old Nov 30, 2001 | 08:47 PM
un4givin89's Avatar
I just remove the hoses and reroute the belt with a shorter one, this way when Inspections come once a year I slap those hoses back and put the old belt on.
Old Nov 30, 2001 | 08:55 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I just pulled the vanes out of the pump and put it back on. No short belt needed.
Old Dec 1, 2001 | 10:05 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
I removed mine completely, hoses and all. I couldn't keep the pump on the bracket or it'd be in the way of the belt.. took quite a bit of patience to get those bolts out of the pump, but it came out fairly easy. as for the hoses, I think I used a 3/4" heater hose cap on the AIR lines from the manifolds, and clamped them down good with the stock clamps that were on the hoses to begin with.. I also removed the line going into the cat, which wasn't too much trouble, since I have no A/C to get in the way. it's only held in by a couple bolts and then you can just clip it at the cat and seal it up. I actually bought a new cat and put it in, so I didnt' have to worry about sealing it off.
by the way, my car runs almost perfect emissions, even with no smog equipment.. not that that matters... I like being an inspector
1991 Firebird 5.0L TBI
K&N X-stream Open Element Assembly
Dynomax Super Converter, 2.5" Cat-back Exhaust
Accel Supercoil, Accel 8.8 Wires, Accel Header Plugs, Polyurethane Tranny Mount, Trunk Mounted Battery, 120lb Weight Reduction
http://home.nc.rr.com/kevin718
Old Dec 2, 2001 | 02:37 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
atcually its under the a/c not behind it. Its the pulley thingy right under it. Its very easy to remove. And it frees up alot of space once you take it out.
Chris
91 RS 305 TBI
Eternal Rev
Also check out TEAM FLYING SAUCERS - http://saucers.speedhawaii.net
[This message has been edited by REVLIMIT (edited December 02, 2001).]
Old Dec 2, 2001 | 03:06 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
<font face="Verdana, Arial" size="2">Originally posted by jcb999:
I just pulled the vanes out of the pump and put it back on. No short belt needed.</font>
Me too, much easier.
italiano67
Dec 11, 2016 09:21 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
jackhammer
Aug 15, 2015 10:04 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
