error codes 24 and 41
Old Dec 2, 2001 | 02:38 PM
84Camaro305's Avatar
Car: 1989 Pontiac Firebird
Engine: 305 TBI
I haven't had an ECM in my car ever since I bought it, which is about 2 months or so. I put an ECM that I had in the back of my car (guessing the guy who had it before was going to swap...because the original and the replacement were in my trunk) so I put the working on in the car. Car seems to run about the same though. It gives me a code 24 and 41.
Error code meanings:
24. Circuit fault in vehicle speed sensor
41. Fault at cam sensor OR Cylinder select error OR Tach input error
How would I go about checking and fixing these problems?
Old Dec 2, 2001 | 03:34 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
What all has been done to the car (i.e. is the stock distributer in there, or a vacuum advance distributer). If the stock distributer was removed in place of a vacuum advance, that may explain the code 41, or maybe its just unplugged. Check the connections around the distributer.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 2, 2001 | 08:27 PM
Engine: 305 TBI
I'll check the distributor connections as soon as I get a chance. How do I go about fixing the code 24 problem? Also, next to the MAP sensor (left side of engine on bracket) there is a little rubber turbe to the left of it that's supposed to go to the right of the MAP sensor somewhere. What does the tube go to and what does it do? My tube is only 3 inches long and goes to nothing.
Old Dec 2, 2001 | 08:59 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the map sensor vacuum hose goes to manifold vacuum. hook it up to a source of vacuum. the computer uses the vacuum reading from the MAP sensor to determine engine load and proper spark advance curve.
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
[This message has been edited by mystikkal_69 (edited December 02, 2001).]
Old Dec 2, 2001 | 09:02 PM
Engine: 305 TBI
Where exactly would I hook this hose up to? I'm not sure where to look.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
