Cloyes timing set=no clearance to cam retainer
Old Nov 19, 2005 | 02:33 PM
crewguy's Avatar
I bought a Cloyes 9-1145 timing set for a Vortec rebuild. Problem is- once I install cam sprocket to cam ( with cam retainer bolted in) the cam sprocket binds up against the retainer plate. If all 3 cam bolts are in place and torqued down-there is no way you are gonna turn the cam sprocket. I bolted the sprocket to the cam as a mock-up (without the timing chain in place). Do I need a spacer? BTW- this is a roller cam w/ indention on front of cam.
Old Nov 19, 2005 | 07:27 PM
crewguy's Avatar
Disregard.............I guess I had the cam sprocket cocked in some way. All is good now!
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
