350 or 355? which one to choose
Old Dec 3, 2001 | 10:47 AM
silentneko's Avatar
I'm wondering which engine is better in these ways:
1. reliability
2. build cost
3. power (daily driver, some drag, and maybe auto x)
4. redline
5. streetablility
neko
'87 trans am
car in the making
angelfire.com/fl2/neko
Old Dec 3, 2001 | 10:53 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
a 355 is just a 350 that has been bored .030". Most 350s will get bored when the motor is rebuilt. The only reason not to is that you are reusing a highquality piston with little mileage.
Old Dec 3, 2001 | 11:06 AM
silentneko's Avatar
ok I thought the 355 was a 305 with a 400 crank? or is that a 335, if so switch it in place of the 355 for the question.
neko
'87 trans am
car in the making
Old Dec 3, 2001 | 11:10 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
a 400 crank in a 305 is a 335. But, its more of a pain than it's worth. Get a 350 or 355 and you will be leaving them in tire smoke.
Old Dec 3, 2001 | 04:56 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
<font face="Verdana, Arial" size="2">Originally posted by jcb999:
a 355 is just a 350 that has been bored .030". Most 350s will get bored when the motor is rebuilt. The only reason not to is that you are reusing a highquality piston with little mileage. </font>
Actually, the only time you should overbore a block is when the cylinder linings are worn, scarred or have a ridge at the top of the bore. Most reputable machine shop (especially those that know what they are doing) will advise against a needless overbore, and do a hone job to re-establish the cross hatch. Otherwise, you are just wasting money becuase: 1. the overbore is not needed, 2. you now have effectively one less rebuild the engine can take. Never reuse pistons on a rebuild, that is only when you just plan on replacing the rings. This is not a rebuild.
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SCFB, SC3GFB, SSOA #M01-0391
[This message has been edited by MRZ28HO (edited December 03, 2001).]
Hotrodboba400
Dec 10, 2019 07:07 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
