No go when hot
Old Dec 3, 2001 | 05:09 PM
danbo's Avatar
No go when hot
I have '86 305 motor (fuel injection)in my '59 half ton pick-up. The motor won't start when hot, but will start again after sitting for 20 minutes or so. Any ideas what the problem might be?
I've already replaced the starter, plugs & wires, & ingition module.
Old Dec 3, 2001 | 05:29 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Is it cranking and not starting or does it not crank at all?
If it's not cranking until it cools off it's probably starter heat-soak problem.Could also be ignition advance related if it seems to be firing against the starter, this is aggrivated even more by heat.
-Rich-
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
