Emission Help Needed
Old Nov 21, 2005 | 09:42 AM
igotoxs's Avatar
Car: 1986 C4 Corvette
Engine: 350 TPI L98
Transmission: Doug Nash 4+3
Axle/Gears: 3.07
My 1989 T/A 305 TBI will not pass emissions testing. It is failing because of NOX and THC. What is wrong and how do I get these levels to acceptable? Thanks.
Old Nov 21, 2005 | 10:36 AM
Sounds like it needs a new cat.
How old is the one that's on it?
Old Nov 21, 2005 | 10:40 AM
igotoxs's Avatar
Engine: 350 TPI L98
Axle/Gears: 3.07
I do not know for sure but would guess that it is the original CAT.
Old Nov 21, 2005 | 02:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A new cat may lower the readings, but an old cat probably isn't the cause.
High NOx is caused by high combustion chamber temperatures. The factory contolled this via the exhaust gas recirculation valve (EGR valve), which introduces a little exhaust gas to the intake charge to dilute the mixture under high combustion temp conditions - which has the effect of lowing combustion temp. It is pretty typical to have the EGR passages plug up over time, especially older engines with compromised valve stem seals. Removing the intake manifold and cleaning the passages usually helps. It could also be a bad EGR valve.
High hydrocarbons is caused by incomplete combustion. This is typically a cylinder misfire. If you haven't done a complete ignition tune-up yet, you'll probably find the issue in the spark plugs, plug wires, cap, or rotor. It could also be a weak coil or ignition control module, but if you aren't noticing any other performance problems, it probably isn't one of those guys.
Old Nov 21, 2005 | 03:26 PM
igotoxs's Avatar
Engine: 350 TPI L98
Axle/Gears: 3.07
OK, I am a dummy. Where is the EGR Valve?
Old Nov 21, 2005 | 03:47 PM
five7kid's Avatar
On the intake manifold. Beside the throttle body unit, passenger side.
Old Nov 21, 2005 | 07:22 PM
igotoxs's Avatar
Engine: 350 TPI L98
Axle/Gears: 3.07
Does it have two large round disc like objects on either side?
IROCZ1989
Jan 24, 2016 03:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
