exhaust leak or engine noise?
Old Dec 3, 2001 | 12:17 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
Ok, I tried searching the archives but I couldn't find anything. My car makes kind of a knocking or clicking sound when it's at idle. I had a 92 firebird that made a similar sound and I found that it was a small exhaust leak. The car I have now used to leak a little antifreeze but I havn't had to put antifreeze in it for about 3 months, so I think that I fixed the leak when I put in the new thermostat. Anyway, it runs fine but the noise is annoying. I still have the original manifolds on it, but I'm not sure if it's that or a clicking in the engine. Can anyone help?
Old Dec 3, 2001 | 12:30 AM
Vader's Avatar
Smnit,
If you have a long-handled screwdriver with a clean handle, you can position the tip on the head or block near where you think the noise is originating. Hold your ear to the handle end (watch out for clothing, long hair, jewelry, etc) and your screwdriver/stethoscope should help you determine if it is a mechanical noise. Of course, if you have a mechanic's stethoscope, that would be even better.
If the noise is not apparent through the screwdriver/scope, try moving it around to different points on the engine. If the noise is completely external, there's a good bet you have an exhaust problem. Don't forget about the 'Y' pipe joints and oxygen sensor as potential leaks, as well as the manifold gaskets. A loose EGR valve can also create the same noise.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It could be an exhaust leak, if it seems to be coming from down behind the engine. If it's near the valve covers, you might have a collapsed lifter. Usually you can tell, because the ticking will get faster as your rpms raise, but both of these problems will cause that.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Dec 3, 2001 | 12:44 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Thanx for the help, I'm gonna check the manifolds and Y pipe tomorrow and check for exhaust leaks, if it is a collapsed lifter how hard is that to fix? I'll update tomorrow when I check it out for sure. Thanx again.
Old Dec 3, 2001 | 06:21 AM
SgtSkip's Avatar
HOw about a kind of muted rattleing noise from rhe rear bottom of the motor. Faster or slower in conjunction with idle speed. Started up about 2 weeks ago for me.
85T/A 305/QJ work in progress.
Old Dec 3, 2001 | 09:52 AM
Car: 99 Formula
Axle/Gears: 342
<font face="Verdana, Arial" size="2">Originally posted by SgtSkip:
</font>
I would check for any loose clamps near the y-pipe area.
Old Dec 4, 2001 | 02:26 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Well, it sounds like the noise is coming from the valve covers. I think it might be a collapsed lifter. What is the easiest way to fix this? Will it cause serious problems if it's run like this for a coupla weeks? Thanx 4 ur help.
theshackle
Sep 17, 2020 08:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
