Check Engine Light
Old Nov 23, 2005 | 07:35 AM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Check Engine Light
I put this is FAQ but I wasn't really sure where to put it and nobody responded to it in FAQ so I decided to put it here.
My check engine light came on, I don't think it has to do with the o2 sensor, anybody got any other ideas as to what it might be?
Old Nov 23, 2005 | 09:29 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Check out the tech articles, or just do a search...
cross the A-B terminals on you aldl connector and turn the key to run, it will flash 12 (1011) 3 times then any codes.
Theirs also a list of the codes in the tech section.
Edit:
Here scroll down to the bottom of this page, it has everything you need to pull codes.
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
