Smoking Problem, plz help
Old Dec 4, 2001 | 09:47 PM
Syrin's Avatar
i have an 84 berlinetta with a 350, sometimes when i start it and rev it, it puts out black smoke and it leaves residue on the snow, this doesnt happen all the time or when im driving that ive noticed, i know when i got the car it was sitting for maybe a month or so but im not sure, i was told its burning a little rich but i want to get some more opinions and find out if this is a serious problem...
Old Dec 4, 2001 | 09:59 PM
breathment's Avatar
admitting ur problem is the first step to solving it.
when was ur last tune up? and how does it run when idling, and misses or rough idle?
wut about ur oil, u leaking much?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Dec 4, 2001 | 10:05 PM
Syrin's Avatar
tune up...no idea ive had it for 3 days...
Idle..Sometimes fine sometimes it sounds rouph like misses i guess..like if it warms up it sounds ok but when u first start it in the cold it goes back and forth from missing to nice sounding
No oil leaks as far as i can tell...oil color is black it looks like..
Old Dec 5, 2001 | 12:26 AM
Syrin's Avatar
bump
Old Dec 5, 2001 | 01:34 AM
BadIroc's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 Crate Motor Holley Stealth Ram
Transmission: WC T-5
Sounds like your running too rich, but sounds like you are too rich, do you run any codes? Make sure ur MAF isnt bad if its FI if not I duno becuase i dunno too much bout carbs
1988 Camaro Iroc-z
305 ci Tuned Port 700R4
3" Exhaust/Flowmaster 80 series muffler/Dynomax high flo cat
hypertech chip/k&n filters
Cut out MAF screens
TPIS Airfoil
"Camaros RULE!!"
"Theres no replacement for displacement"
SAVE THE F-BODY!!!!
Old Dec 5, 2001 | 01:37 AM
BadIroc's Avatar
oops sorry kinda repeaded my self, i typed somthing else but i erased it, then I forgot to erase that sorry!
Old Dec 5, 2001 | 08:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm going to go out on a limb and assume that this is a carbes car, with the stock computer-controlled Q-Jet...
If it only does this when the engine is completely cold, then the choke is out of adjustment, or it needs a new choke pull-off diaphragm. Is the whole computer system still hooked up and operating properly? If it's not, but you still have that carb, it will run rich all the time except maybe at WOT.
ICON Motorsports
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
