Replacement motor
Old Dec 5, 2001 | 11:28 AM
JaKeDaPlAyA's Avatar
Replacement motor
Anyone have reccomendations where i can get remanfactured long block 350? Has anyone heard he place called the engine fatcory??
What do you think?
Old Dec 5, 2001 | 11:38 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I bought a motor from the engine factory, the motor was pretty good for the time that I had it, they simply build them back to original spec and I think that they throw on like a high flow oil pump. If your looking for a performance block though I would probably recommend like GMPP or any of the other performance shops.
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Dec 5, 2001 | 11:43 AM
CamaroZ_85's Avatar
look at the aftermarket parts board, theres a post on there about the GM 330HP HO Deluxe 350, you might be interested in that
TheExaminer
Aug 26, 2015 04:59 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
mdtoren
Aug 16, 2015 05:45 PM
Leggman1
Aug 6, 2015 04:15 AM
NBrehm
Aug 5, 2015 07:57 PM
