stalling probelm?
Old Dec 4, 2001 | 08:41 PM
britered86transam's Avatar
stalling probelm?
today i was goignt hrough BK drive through and my car jsut stalled out and my SES light came on, i put the car in park and staterd it back up and it was fine.....whut could have caused the stall?
Old Dec 4, 2001 | 08:54 PM
Vader's Avatar
Brit86,
There are a few possibilities:
Lack of fuel mixture;
Lack of ignition;
Lack of compression;
Incorrect timing.
With all those items, an engine will generally run. Since your car is an '86 TA, it could have had either of two engines and fuel systems. A little more detail would be good, since diagnosis for a carburetor would be a lot different than for a TPI system.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Dec 4, 2001 | 08:55 PM
Vader's Avatar
Incidentally, the SES or MIL lamp should always turn on when the ignition is on and the engine isn't running (Code 12 - no ignition reference pulses).
Later,
Vader
Old Dec 4, 2001 | 08:59 PM
vader, i have a 305 TPI
Old Dec 4, 2001 | 09:17 PM
breathment's Avatar
how does it run otherwise, smooth idle? loosing power etc etc. wut does it idle at?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Dec 5, 2001 | 07:28 PM
its idles well and at about 500 rpm there is a slight loss of power as well
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
