help me stop smoking!!
Old Dec 5, 2001 | 06:54 PM
dailydriver's Avatar
1986 305 176,000 miles (no rebuild)
on cold mornings when I start the car the engine misses and smokes (blue) until it gets warmed up. Only on cold mornings, in the summer it does not do this. Also, it does NOT use oil between changes (3,000 miles) I ran a diagnostic on the ECM and the code tells me I have a bad EGR valve (which i am going to replace soon) Could it be more than the EGR valve. And if it is the valve seals, why does it only do it when it is cold. Thanks for all suggestions!!
Old Dec 5, 2001 | 07:07 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Try some Nicorete, or the patch. Cold turkey doesn't usually work to well.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 5, 2001 | 07:53 PM
rezinn's Avatar
I'll tell you one thing: its not the egr valve. The egr does nothing when you start the car or idle. When did it start doing this? Its burning oil, probably worn valve guides or seals from oil leaking through while the car sits. I would bet it does it when its warm also, just you didn't notice it, or it only started this winter.
Old Dec 5, 2001 | 08:11 PM
hy-po-ny's Avatar
ill second that cold turkey never works, use nicorette patch & gum.
L8
1976 mustang
4 cylinder 4 speed
simpson racing seat belts
aluminum 13" racing wheels
limo tint
Old Dec 5, 2001 | 08:12 PM
hy-po-ny's Avatar
L8
1976 mustang
4 cylinder 4 speed
limo tint
Old Dec 5, 2001 | 09:42 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Hey now, I quit cold turkey just over two years ago (after somking a pack a day for seven years). It worked well enough for me.
I'll second the valve seal opinion. Mine used to do the same thing until I put a new set of heads on it. Doesn't do it any more.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Dec 6, 2001 | 10:24 AM
82camaro's Avatar
Car: 82 camaro SC
Cold morning, the seals shrink. Also, it has all night for the oil to make it's way past the seal and down the guide. If it isn't using any oil, I wouldn't do anything.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
