Cruise Control--Need Help!!
Old Dec 8, 2001 | 09:23 AM
Harvey1113's Avatar
Car: 1983 Firebird Trans Am
Engine: 305 V8 Cross-Fire
I'm working with a 1983 Pontiac Trans Am. It has the mechanical cruise control transducer (CCT) in it.
The problem is the cruise control fails to engauge and set selected speed.
To resolve this I have tried the following:
1) replaced the CCT itself.
2) replaced the odometer cable from the CCT to the transmission.
3) verified operation of cable from CCT to speedometer gauge.
4) replaced the instrument cluster.
5) using the Helm service manual, performed service procedures and they checked okay.
6) checked to make sure vacuum switch was not operated when brake pedal is at rest.
I would appreciate any suggestions.
David
Old Dec 8, 2001 | 10:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Is this a manual trans car or auto?
ICON Motorsports
Old Dec 8, 2001 | 11:07 AM
Harvey1113's Avatar
It's a CFI 305 V8 automatic with a 700R4 transmission.
David
Old Dec 8, 2001 | 11:12 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Did you test the cruise switch? Those little wires do NOT last forever......
Old Dec 8, 2001 | 11:59 AM
Harvey1113's Avatar
Yes, I have checked the wires, and they are in good order and work properly.
David
Old Dec 19, 2001 | 09:03 AM
Harvey1113's Avatar
Any other suggestions to repair the cruise control?
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
ULTM8Z
Sep 16, 2015 09:15 AM
