1988 2.8 V6 multi port hard starting
Old Dec 1, 2005 | 09:28 AM
Sidnee's Avatar
Hard to start, when it does start it dies when you give it gas, other times (rarely) it will start and run. Have replaced the fuel filter and fuel pump. After I replaced these items, I got a code 44 and replaced the O2 sensor. Checked the Shrader valve on the fuel rail, fuel shot out about a foot. I can hear the fuel pump working and I am getting good spark.
It acts as if something is shutting down the fuel.
Any help would be appreciated.
Sid
Old Dec 1, 2005 | 09:55 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
First off grab a fuel pressure tester, fuel shooting out of the rail doesnt mean your getting full pressure. you can pick up a tester cheap or just rent one.
Another thing that could be cutting fuel is the oil pressure switch, it cuts the fuel pump if it doesnt read any pressure. although im not sure if the V6s are set up like this.
Old Dec 1, 2005 | 09:57 AM
Sidnee's Avatar
I have checked the the oil pressure switch, it is okay. I will be getting a gauge later today. Thanks for responding.
Sid
Old Dec 3, 2005 | 07:16 AM
Sidnee's Avatar
v6 2.8 multi port Help!
Fuel pressure checked at 40+ at start up. Dropped to 38 when first started. Checked the MAP sensor, showed it was bad and replaced it...it still starts and dies, starts and dies. etc. No vacuum leaks, as it does not rev that high. Any suggestions?
Thanks,
Sid
Linson
Oct 24, 2025 02:00 PM
sammy52401
Nov 11, 2015 07:20 PM
86maro_252
Oct 10, 2015 06:52 PM
rjcme
Sep 5, 2015 01:23 PM
