Hard starting
Old Dec 2, 2005 | 11:45 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Hard starting
Lately my car had had trouble starting, especially at the beginning of the day. When I crank the engine for the first time, it won't turn over and I see a little white smoke come out from under the hood. After about 8-10 times of cranking the engine about 8 sec at a time, the car finally starts. When it starts up it runs very, very rough, almost like it's not running on all cylinders. After running for about a minute, it starts running smooth. I'm pretty sure it's ignition related, but I was just wondering if anyone has had a similar experience so I can more easily pinpoint the problem. Thanks
Old Dec 2, 2005 | 11:54 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Running a carb or EFI setup?
If its a carb my first guess would be the choke is either improperly adjusted or foobared.
Old Dec 3, 2005 | 10:46 AM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Whats your initial timing set at?
Old Dec 3, 2005 | 11:14 AM
85cmroz28's Avatar
Engine: L69
Running a carb, choke seems to be working fine. Initial timing set at 8*. Haven't had this problem before- it's been starting fine for a long time and this problem just started a couple of days ago.
Old Dec 6, 2005 | 02:38 PM
85cmroz28's Avatar
Engine: L69
Just wanted to post this in case anyone else is having the same problem. I replaced the ignition coil and everything starts up great now. Thanks for your replies.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
