EGR valve leakage
Old Dec 4, 2005 | 10:52 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
EGR valve leakage
When testing an EGR valve with a vacuum pump, should the valve hold a vacuum?? Mine actuates when vac is applied, but within a couple of seconds, the vac bleeds off. I'm thinking it is supposed to hold a vacuum, but want to make sure before I go out and buy another one. (The vac pump and the hose were verified not to be leaking)
Also, where does the EGR vac solenoid mount??
Thx!
Old Dec 4, 2005 | 12:16 PM
Vader's Avatar
Presuming this is on your '87 TPI conversion, the EGR valve is a negative backpressure design:
There is a pilot valve within the EGR that will bleed off the main vacuum source unless there is a slight pressure differential across the two valve ports. Testing with a handheld vacuum pump may not yield the results you expect.
Old Dec 4, 2005 | 12:18 PM
Vader's Avatar
You can try this to help diagnose the possible valve problem:
Old Dec 4, 2005 | 05:02 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Thx for the reply Vader!!
Yes, the EGR valve in question is for my 87 TPI eng.
Currently, the eng is on the eng stand, so I can't use the flow chart.
I was wanting to confirm the egr valve ops before I installed the runners and plenum and save myself the expense of having to buy a new set of gaskets for the Hi-Flow runners ($$$) if it does need replacement.
Anyone have a pic handy of the EGR valve vac solenoid mounting??
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
