Need HELP Passing Georgia Emissions
Old Dec 8, 2001 | 11:37 PM
ptc92rs's Avatar
The last time I had the test done I failed HC and CO. HC was 138 and the limit was 108. CO was .71 and the limit was .60. NO passed with 389 and a limit of 751. The patient is a 92 3rd Gen RS 350 TPI. I have made some changes since then but I'm not sure if they were all good, mostly because I'm not sure what kind of problems make the HC and CO go up. I have been burning chips to fix some drivability problems. The Fuel mixture has been trimmed, (Was running rich) and I installed a 190 Deg T-stat and reset the computer to turn the fans on at the appropriate temp. I have also tweeked (retarded)the spark curve in different areas throughout the RPM range to get rid of a spark knock problem I was having.
I guess the bottom line is that it's time to get through the state circlejerk and I'm just wondering how these changes might affect my readings and what else I should or could do to pass this thing the first time.
(I passed by accident on the fourth time last year. The guy accidently entered my car as a 4 Cyl and aparently a 4 Cyl can put out twice the emmisions of a V8.)
One other thing. This is a Dyno Test. (25MPH I think) The car was originally a 305 TBI. When I did the engine swap I installed all of the emission stuff that should be there. No modifications other than the T-stat and chip.
'92 RS 350 Big Mouth TPI 5spd 2.73 lmtd slp Daily Driver with "ISSUES"
[This message has been edited by ptc92rs (edited December 09, 2001).]
Old Dec 8, 2001 | 11:44 PM
LincolnHawk's Avatar
this is the obivous yet many dont have the ***** to do it...
bribe
85-iroc
1 of 85,ooo or so
superunleaded gas
mods include:K@n stickers
octan boost<<autozone>>
removal of floor mats for less weight
Future mods
More stickers
mothballs
best time est.
6.8@210 m.p.h
392 kills
losses
nhra funny car
747 jet..it was nose to nose
Smoking Vipers
1 by 1
Old Dec 8, 2001 | 11:54 PM
ptc92rs's Avatar
Been there tried that! But good suggestion!
I flat out asked the guy what it would cost to get out the door with a green slip.
He said, "Listen, If I said $1000 you wouldn't pay, but even if you did It would spend pritty fast after I lost my job. It would be cheaper for both of us to just do this the right way."
Old Dec 9, 2001 | 12:54 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I don't know how close you are to Florida, but if you're pretty close you could always get a florida license on the car and inspect it down here. The emissions aren't near as strict down here, so you could pass easy. Just blerting ideas.
Old Dec 9, 2001 | 08:26 AM
ptc92rs's Avatar
I'm not exactly sure what the DRY GAS trick does.
Would it help this situation?
What about retarding the timing? What does that change?
Old Dec 9, 2001 | 10:05 AM
DiecastZ28's Avatar
If you dump a whole lot of dry gas in you will probably pass, but it will mess you your engine big time. I wouldnt recommend it.
1985 Camaro Z28
305
5-speed Transmission
Flowmaster Exhaust
4 barrel carb
8mm wires
Kenwood 600 amp
Sony Deck
4 6x9 Jenson Speakers
2 4x6 Polk Audio
2 10" JL w0 Subwoofers
Old Dec 9, 2001 | 10:08 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Try a new cat. Not the furry kind.
ICON Motorsports
Old Dec 9, 2001 | 12:04 PM
iroc5speed's Avatar
Put in a high stat. From an emissions tester I leaned that running the car hot cuts down on emissions, so, run it 225 and you'll be fine. Also, try dumping some fuel injector cleaner in the tank, he said that helps too.
Old Dec 9, 2001 | 10:39 PM
FstBrd6point3's Avatar
kick yer timing back and restrict yer intake, go back to stock if U don't have the stock elbow on there, hell stuff the canister if U need to, my bro did it after scoring 3x the allowed HC in CT, and then he passed with flying coors. . good thing is it is all free too
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
