Installing rebuilt engine, have question
Old Dec 6, 2005 | 07:20 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Installing the distibutor: looking at the engine from the front, the first cylinder on the right front is TDC. When I drop the dist and rotor in the rotor should point to the cylinder correct?
Harmonic balancer: What is the correct wat to put it on?
Tony
Old Dec 6, 2005 | 07:34 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
TDC of which stroke?
Borrow the tool and avoid headaches.
Old Dec 6, 2005 | 07:45 PM
Car: 1986 Iroc-Z
1) not sure, machine shop just said it was TDC.
2) I have a harmonic balancer puller, is there a Harmonic balancer installer? Or is there another way of using the puller to use as an installer?
Old Dec 6, 2005 | 08:33 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
yes there's a harmonic balancer installer, it thread into the crank and has bold on the outside that presses the balancer on
Old Dec 6, 2005 | 08:36 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Or use the best tool in the shop, a hammer!
Ive done it to a few of my junker motors but you are best off renting the tool and doing it properly.
Old Dec 6, 2005 | 08:45 PM
if you choose to do the hammer route (which I've done but don't recommend) clean the crankshaft and dampner then lube the **** out of it. Get a block of wood and tap GENTLY.
Old Dec 7, 2005 | 11:11 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It's impossible to know how to set up the distributor without what piston is TDC firing. Either set/reset it to #1 TDC firing yourself, or call the shop and get the information out of them.
Don't whack on the balancer. Rent/buy/make the tool.
Old Dec 8, 2005 | 09:33 AM
beedo's Avatar
Car: 1986 IROC CAMARO
Axle/Gears: 3.73 posi
If they set the cam "dot to dot" and didnt roll it over any the engine as tdc of #6
Old Dec 10, 2005 | 06:31 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
when the shop did my engine...yes the motor was set up for tdc where the dizzy should point to the front right cly if your looking at the motor from the front...i dont know if everyone does it that way, but my machine shop did
Old Dec 10, 2005 | 05:39 PM
Car: 1986 Iroc-Z
The piston is at the top, should the valves be open or closed to have it ready to install the distributor?
Old Dec 10, 2005 | 11:22 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have done this several times.
You want to install the dizzy with the #1 piston at FIRING TDC. You know that it is firing TDC when the rocker arms on #6 are rocking, then#1 has to be at firing TDC. Just drop in the dizzy,, the rotor will point to the post which goes to #1 cylinder. (edit: Both valves on #1 must be closed) With that said, you can actually drop in the dizzy and have the rotor point in any direction allowed by the gears. Most builders drop in the dizzy so that the rotor points toward #5.
Old Dec 12, 2005 | 09:58 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
you can make a harmonic balancer installer very easily, just get a piece of all thread like 6 inches long with the same treads as the balancer bolt, 1.09$ home depot, and a nut that fits it, 0.10$ big washer, 0.10$. Thread the all thread in, put the balancer over the all thread, put a really big socket over the all thread, put on the washer, and put on the nut. Just spin down the nut till the balancer is pressed all the way on. you just made the tool for 1.29$ lot better than running a 100$ balancer and possibly damaging a 150$ crank.
Old Dec 27, 2005 | 05:33 AM
Car: 1986 Iroc-Z
Rented harmonic balancer installer, easy as pie and I did not rune the crank a second time, costly mistake! As for the #1 TDC, thanks all. I figured it out. The valves are closed on #1, the piston is all the way up and #6 is a rockin. Thanks all, now trying to finagle that thing back into the engine bay, fun!
Old Dec 27, 2005 | 07:28 AM
i hope you have the distributor out for reinstallation. Just for safety sake. I didnt' take mine out when I took the motor out and smashed it all to ****.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
