timing retarded but will not respond to kicks and punches
Old Dec 9, 2001 | 01:23 PM
firbird's Avatar
ok i have been tring to get my timng right on my new engine and when i advance it to 10 deg advanced with the est unhooked and when i check it, it goes to somthing like 20 deg retarded or more when i hook it back up. and i have surging problems and doesnt seem to like it, it seems like it is picking up knock or somthing because it retardes it tooo much. and i have heard that spark can do that, but when i set my timing without using the est wire unhooked, and advanced to justt to 0 it will idle great and is very smooth, BUT it boggs really bad and and when i try to push 1/4 throttle it makes a big clacking noise and sometimes dies and sometimes it saves itself. and if i put it back retarded it willl not do that but it will have the surging problems but it willl not bogg nearly as bad.... ??? any clues becasue i am lost
Old Dec 9, 2001 | 06:14 PM
ede's Avatar
ede
sounds to me like the est is working, also sounds like you have knock and it's changing your timing too much. maybe a loose rocker, too much cam, or need more octane
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Dec 9, 2001 | 06:39 PM
firbird's Avatar
i thought valve train could not mess up the knock sensor to set it off, and the octang should be more than good engouh get the best kind and dont have extreme compression. cam its fine its not to big
Old Dec 9, 2001 | 09:41 PM
firbird's Avatar
btt
Old Dec 10, 2001 | 05:31 PM
firbird's Avatar
well i have made things even more complicated. i have unpluged my kock sensor and it still retards it... and it will go back to normal when the est wire is unhooked with knock sensor or without knock sensor.
and if it helps any i dont have a egr
[This message has been edited by firbird (edited December 10, 2001).]
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Apr 14, 2017 05:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
