No fuel gauge input
Old Dec 6, 2005 | 08:08 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
No fuel gauge input
I am not getting any voltage that I can read on my digital multimeter when I test my fuel gauge input from the tank. I wouldnt imaginge this part could go bad, is it not simply a potentiometer?
any ideas? Maybe it uses a resistance level? I have it hooked up to the green wire on the back of the gauge panel, but dont read anything. Should I read something from the line on my meter? If so, what?
Yes, I had gas in the tank, almost full.
Old Dec 6, 2005 | 08:25 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
yes they go bad. what I thought was vapor lock was me running out of gas when the gauge was at 1/2 tank.
Old Dec 6, 2005 | 08:33 PM
Car: 88 Camaro
Engine: 310 LG4
damn. guess i'll drive 100 miles then fill up lol!
Old Dec 6, 2005 | 08:36 PM
guess it sucks to be us, my tank isn't coming out until a posi is sitting there ready to go in.
Old Dec 6, 2005 | 08:37 PM
Car: 88 Camaro
Engine: 310 LG4
agreed 100%
Old Dec 7, 2005 | 08:11 PM
Firebat's Avatar
the fuel gage sender is a potentiometer. Reads 90 ohms when full, 0 ohms when empty. Could be your contacts on the connectors are dirty, not making a good electrical connection. Its also possible that this bad connection could be inside of the tank. It might be possible to measure at the connector before it goes to the tank, dont know b/c i measured there when i had no exhaust on. To fix dirty connectors, just scratch them with a knife to remove the corrision.
Old Dec 7, 2005 | 08:37 PM
Car: 88 Camaro
Engine: 310 LG4
This is a complete tear down/rebuild of the car. The wiring is brand new, so it's not dirty. However, when testing the old pump, we put the wrong wires on the battery, so i'm not sure if it killed it that way. The tank assembly was junk yarded, dunno if it worked b4. If it works on ohms, i might not have tested for ohms. I think I only tested for voltage. If that is the case, I might have it hooked up to the wrong wire.
My overall question is, "Can the sender go bad". If it's just a potentiometer, then i'm ok.
Thanks for the info!
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
