Great, now i get to spend more money on my !@#$ Camaro...
Old Dec 10, 2001 | 01:57 PM
KlayBuRn's Avatar
ok heres the deal...
1992 305 TBI Auto Stock RS
the car worked just fine this last week, and all that, havnt been having a problem...
i parked it saturday night about 3 in the morning, it sat all night, all day, and at around 7 sunday night, i tried to start it, and it started to turn but wouldnt, i tried and tried and tried, hit the gas a little, and it turned over, idled a little rough, but i just thought since it was cold and sitting it would do that, went to start it today(monday afternoon), and it started up fine(i have a remote starter and started it before i went out to the car), and i go out, its idling high, there is a mega loss of acceleration, and the service engine soon light flicks on and off very fast...
i tried plugging in my key to get codes, but nothing showed up...
any ideas?
Old Dec 10, 2001 | 04:39 PM
breathment's Avatar
if the light is flickering on and off quickly, it sounds like the ECM is in field service mode for some reason. maybe ur ECM is fried. just a guess!!
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake, and an Energy Suspension Poly trans mount that is worse then the broken rubber tranny mount
http://www.geocities.com/david_angel_16
Old Dec 10, 2001 | 07:29 PM
KlayBuRn's Avatar
well, i went to work today, which is where im at now, and the car started up just fine, no problems so far, ive also been to lunch, still no problems, me and my friend have a custom PROM in there, im gonna check and see if that is coming lose or something...
Old Dec 18, 2001 | 01:18 PM
KlayBuRn's Avatar
Ok, its back again, now about everytime i turn my car on, the service engine light soon blinks repeatedly, loss of acceleration, idle in drive and others is 1000rpm, and 1500 in idle, and after driving for 30 mins to an hour, it just stops and drives normal, i have a moded chip in there, could that be the problem? i just want to have anymore opinions, im gonna try dropping my stock chip back in tonight...
thanks
Old Dec 18, 2001 | 01:45 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I'll bet its your fuel pump.
I had a very similar problem, took almost 3 weeks before I even got an SES code. If you can get a fuel guage and check the pressure.
Old Dec 18, 2001 | 02:01 PM
leirch's Avatar
Man, its the chip, I know, I wrote it for you. Put the stock one back in and it will work fine.
Old Dec 18, 2001 | 06:32 PM
KlayBuRn's Avatar
Ok, i put the stock chip back in, and the car still runs the same(loss of accelration, if i mash it, it doesnt shift till high in the RPM's), still idles at 1000rpm in drives, 1500rpm in neutral, but the service engine soon light is solid now, and if i put my GM key in the ADL or whatever connector, i get no codes, ILF RST or whatever that is blinks a few times(normally before, the service engine soon light would blink a few times, but it doesnt now, it just stays on solid)...
anymore ideas?
Old Dec 18, 2001 | 07:39 PM
KlayBuRn's Avatar
Ok, bent pin on the stock chip, restraightened it, and it worked fine, put the mod chip back in with the carrier thing, works fine, so its all good, thanks for the help!
Old Dec 18, 2001 | 08:03 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
TPS my man. I've had mine replaced twice for similar symptoms.
Old Dec 18, 2001 | 10:32 PM
TBIfly's Avatar
If it ISNT the chip, i had a similar problem but just the extreme loss of power thruout the power band
i turned a 32, EGR
plugged it and havent had the problem since...that was 5 mos ago on my 91 RS
Old Dec 18, 2001 | 11:54 PM
Dan91Z's Avatar
i have been having this same exact problem for about 3 weeks now..
i'm thinking it's my ecm acting up.. i replaced it a little over a year ago when i thought it was bad,.. kinda wish i kept the old one cause it turned out it wasn't bad.. it was a shorted fuel injector on my car :-(
and the ecm only came with a 1 year warranty which just ended like last month :-(
https://www.thirdgen.org/techbb2/sho...490#post439490
Old Dec 19, 2001 | 12:06 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
When I read of all you guys' problems with all these electronic doo-dads and gizmos, not to mention fuel injection, I thank the Lord I just have a simple old carb and HEI distributor
Old Dec 19, 2001 | 01:02 AM
KlayBuRn's Avatar
You may have to pardon my car techo stupidity, but how can a mechanical carb give you better performance than a computer that can monitor, adjust, blah blah blah, on the fly, with a single chip, and no mechanical tuning needed?
Old Dec 19, 2001 | 01:21 AM
Engine: 305-4v
Well, it has to do with SIMPLICITY
When things go wrong on these fuel injected cars, people have an absolute fit trying to track it down. Carb and vacuum advance is just a lot simpler--with a whole lot less that can go wrong
Not to mention the costs of these fuel injected parts
Old Dec 19, 2001 | 01:43 AM
KlayBuRn's Avatar
that jus the way it is or can i get an arguement for the other side ?
Old Dec 19, 2001 | 01:48 PM
mcconahay37's Avatar
I've thought hard about getting an EFI car, but every time I think about it, I look at my engien bay and think, man it's so nice not to have a whole bunch of stuff in the way. Even the cleanest efi car would be hard pressed to have as clear of an engine bay as mine. Like has already been said, carbs and a mechanical HEI are simple and easy to diagnose. It's a lot easier to change a carb than to change injectors and computer programming. For me to put a bigger carb on, it takes maybe 15 minutes and then some tuning time. A carb is like the most effective MAF ever designed. It brings in air, mixes the fuel, and sends it on its way.
Noe for EFI. It is much more efficient than a carb. Better fuel mileage will result. You can usually run more compression than with a carb. Because it is more precise, turbochargers have finally been able to really come in to general use.
There are lots of pros and cons to each system.
Jake_92RS
Jan 28, 2020 10:37 PM
mustangman65_79
Apr 14, 2017 05:37 PM
camaroinmotion
Exterior Parts for Sale
Sep 2, 2015 08:25 AM
dyeager535
Aug 28, 2015 08:10 AM
lt1z350
Aug 28, 2015 05:57 AM
