car seems to have a backfire like sound out of the intake
Old 12-08-2001, 11:24 PM
killer305's Avatar
how it going, i recently turned up the fuel pressure in my car from 12 psi to about 12psi and realized my hesitation and wooshing sound out of the intake have gotten worse. what happenes is when you give it gas, it makes a woosh sound out of the intake. and when in park if you tap the gas real quick it hesitates, can someone point me in the right direction to what the problem is. the engine has 560 miles on it, so i am starting to think i did not do the valve lash right, does this sound like the problem or is it something else
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player,autometer phantom gauges, soon to have 91-92 gfx, z-28 wing, new paintjob, rims, all new suspension, and new inteior
Old 12-09-2001, 06:05 AM
86Z
86Z's Avatar
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
could be your valve lash, do you hear any ticking? i had a bad lifter in my motor and it would "pop" like out of the intake, check all your vacuum hoses also.
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old 12-09-2001, 10:57 AM
killer305's Avatar
there all bradn new crane roller lifters so i doubt they are bad, i think ill check my vacume lines over, because i know i had a crack in one earleir
Old 12-10-2001, 08:39 PM
killer305's Avatar
btt
1992 Trans Am
05-10-2023 07:19 PM
midias
08-22-2015 01:42 AM
mustangman65_79
08-08-2015 12:07 PM
gwade12
08-08-2015 08:17 AM
Quick Reply: car seems to have a backfire like sound out of the intake
