Head opinion
Old Dec 7, 2005 | 07:50 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Axle/Gears: 3.42 posi
Head opinion
I currently have bone stock 882 heads and have a guy offering me some 186 heads for $225. The 186 heads are gasket matched, have 1.94/1.5 valves, 1.43" .600 lift double springs w/dampers, ARP studs & guideplates, bronze guides, 165cc runners, 62.5cc chambers. Does this sound like a good upgrade for the $$?
Old Dec 7, 2005 | 08:18 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
NO NO!!
It's a horrible setup! Especially for that outrageous price of $225.
You need to give me his name, phone number, and email address so I can punish him severely!!!!
(Obi-Wan using the force: "These aren't the heads you are looking for" "Move along now")
Old Dec 7, 2005 | 08:27 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
I thought DD2000 was on crack when it listed me as actually losing some power by switching to the 186's Thanks
Old Dec 7, 2005 | 08:41 PM
Engine: 350 4BBL
They have very bad shrouding stock, but ported they will make mundo power.
I'm not sure they have hardened seats, that depends on what year they are.
They are probably worth twice that on ebay.
EDIT: It also depends on if you are pulling off a set of AFR's to put them on....
Old Dec 7, 2005 | 11:03 PM
11 Flat's Avatar
Depends...Do you have the money for any aftermarket heads?
If not I would grap them. If he had bronze guides put in. He probably had hardened seat done at the same time. Find out
DD2 is on crack. Stock camel backs will mop the floor with those 882. You can do a little bowl work before you put them on. Or leave them stock, and still make more power than you have now.
Old Dec 7, 2005 | 11:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The 882 flow numbers in dd are from a set of modified heads...
Old Dec 8, 2005 | 09:46 AM
DD lies when it comes to 882 heads. Don't believe a word it says about them because it doesn't agree with the real world. I suspect 882 Heads Inc. must have paid them to pad their numbers, or something.
You will find that those double-humps, if they're ready to run and don't require more money spent on them, are probably the best $225 you can possibly spend on that motor.
No matter what Desktop Dyno says, I've changed countless smogger heads off of motors for double-humps such as 186s; and EVERY TIME, without exception, got a HUGE positive result.
"Gasket matched" is worthless, possibly even harmful, if the "real" porting hasn't been done.
1.94"/1.5" valves were the stock sizes in sedan type uses for those heads.
Old Dec 8, 2005 | 11:10 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
186 heads wre from 300hp 350's in 1969 1970 and hi perf 302Z28's in 69.
The 1.94 version are the 300hp 350 heads. a good hi perf head. Much better than 882's.
A really nice head if you were to port them.
A good swap.
Old Dec 8, 2005 | 11:39 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I would grab them up and finish up with a full p/p on them.
509 camaro fan
Sep 6, 2015 10:43 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
camaro71633
Sep 1, 2015 10:24 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thornburg
Aug 25, 2015 01:46 AM
