what is the lbs per hour for the Ford F55E-A2E fuel injectors
Old Dec 8, 2005 | 11:11 PM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
Does any one know what is the lbs per hour for the Ford F55E-A2E fuel injectors?
Old Dec 9, 2005 | 11:48 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I believe the F55E is a Denso-made bluetop....24 lb/hr at 14.6 ohms. Not sure on the pressure used to achieve that rating, probably 35-40 static. These are essentially the injectors Im running in my car, but Ive got the Ford injectors so the design is a tad different.
Look about right?
Old Dec 9, 2005 | 06:58 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
Thanks a million for your help, these are the injectors that came with my car when I got it. I finally know the rating! I also have the ford injectors a well.
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
tmellott89
Aug 16, 2015 02:58 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
