Solid lifter cam
Old Dec 10, 2001 | 07:46 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Solid lifter cam
My engine builder told me that he's going to put a solid lifter cam in my car with 510 lift on it. Is this cam going to be powerful and what's all involved with these cams, i don't know too much info about them other than you have to adjust the valves every now and then. I am trying to build this engine to go 12's in the 1/4 mile, so is this a good cam for my engine. Thanks for the replies
1989 Camaro RS, 355 engine, 4 bolt block, 11.5:1 compression, 305 heads--ported, polished, milled, 3-angle valve job, 2.02 intake and 1.60 exhaust valves, Edelbrock rpm valve springs, 1.5 rockers--, Keith Black pistons, solid lifter cam, Edelbrock RPM intake, 750 cfm Holley, Holley Red electric fuel pump, MSD distributor, Turbo 350 w/B&M Shift kit, 3.73 Richmond Gears, Hooker headers, Flowmaster exhaust
My Pontiac's (my babies)
1972 Pontiac LeMans, 2 Door, red with tan top, 350 V-8, Edelbrock Perf. Intake, Rochester Carb, Turbo 350 trans with B&M shift kit, Dual Exhaust
New Addition (Don't tell my girlfriend!! [she found out...whoops]) 1968 Pontiac GTO, Rust free body, White with Black Interior, Original 4-Speed Car, 400 V-8 engine, Hideaway Headlights, Positraction Rearend
http://www.fbody.com/members/Camrs89/
Old Dec 10, 2001 | 08:34 PM
dropkeel's Avatar
More info is needed like duration at .050 on the intake and exhaust and the Lobe separation angle.Not slamming the engine builder but I question the use of the 305 heads and the money that has been spent on them when ultimately the valves are shrouded by the larger bore.That is not the best way to get into the 12's I know of.My hopes would be this is just a plan and no money has been spent yet.
[This message has been edited by dropkeel (edited December 10, 2001).]
Old Dec 10, 2001 | 08:48 PM
SoCo80p's Avatar
solid lifter cams need the lash set every 3,000 miles, also they make a LOUD clicking. they do make more power then a hydrolic, but i also agree this builder seems a little shady, just dropping off a engine and say "ok, make it run 12's" usally isnt a good idea. its better to plan it out yourself.
Old Dec 11, 2001 | 12:42 PM
Camrs89's Avatar
Yeah, the heads are circle track race heads, but he told me the engine is about 400 horsepower all together.
Tempest68, I take it you own a 68 pontiac tempest? I just got done parting one out for my 68 GTO. Nice car, I wish we could have saved it, but in Illinois, rust had taken its toll on the car. Got any pics?
Old Dec 11, 2001 | 01:51 PM
SoCo80p's Avatar
i got a few pics i could find of it, yeah around here finding a rust free car that old is basically impossible, you know how to link onto here pics? and do i need them on a wesite or can i upload from my computer?
Old Dec 11, 2001 | 06:46 PM
Camrs89's Avatar
yeah, You need a website, you can email your pics to me and i will post them on my site, then you can post them from there.
Where in Illinois do you live? I'm from Peoria.
And what is all involved with setting the lash at 3,000 miles?
Old Dec 11, 2001 | 06:52 PM
SoCo80p's Avatar
im in wheaton, about an hour or so from peoria, if your running a full roller rocker the cam card will list the hot last, and you set the rockers with a feeler gauge, probey take you about an hour or so, what i would do personally is stick with a hyrolic or go with a hydrolic roller if you want to step up to some big power and the price will be $$$ also. if you dont mind the noise and the lash setting then the solid will be ok, but if you like to just drive and not have a noisy engine go hydrolic, im sure you can get the power back elsewhere no problem
[This message has been edited by TempesT68 (edited December 11, 2001).]
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
