Vacuum Diagram
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
Vacuum Diagram
Ok, I've looked all over the board for the answer to my problems, with no luck (vader's diagrams don't seem to be available anymore)
I recently swapped the LG4 out of an '85 burlie into my '87 SC, unfortunatly the previous owner hacked away at the vacuum hoses & the thing runs *chitty*. There was no vacuum sticker under the hood & I can't find any info in my nearest library.
Does anyone have the vacuum Diagram for an 85 LG4 Berlinetta with emmissions equip & no ECM.
TIA, Don
Black 87 2.8l Camaro
Soon to be 305/5.0
http://photos.yahoo.com/bc/z2point8l?d&.flabel=fld1&.src=ph
Aka Z2point8
TIA, Don
Soon to be 305/5.0
Aka Z2point8
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
can't anyone help me? I've searched local parts stores & even Wal-Mart & no one here carries Chilton manuals; just Haynes
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Good luck!! I've been trying to get something here for around a year and a half with no luck. One thing though, The LG4 needs the computer to run right. With out it, the carburator goes to full rich, and you will bog, and have black smoke out the rear when you jump on it. That's what happened to me. I see it all the time. Any other ?'s,?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
I found out that my parts car (berlie) was one of a few export (canadian) that wasn't factory equipped with the ECM.... There definatly wasnt one when I pulled the engine
Thanks,
Don
Thanks,
Don
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Thanks,
Don
Thanks,
Don
That's pretty cool. I didn't know that it was a canadian car. I assumed that you came down and plucked one. Once again I learn not to assume!!
Car: Trans Am
Here I come to save the day....Nightcruzer is on his way...
Sorry feeling a little silly, it is Friday.
Anyway CanadianCamaro your vacuum diagram is below.
NOW, Stingerssx, a year and half IS a long time to wait, but better late than never. What vacuum diagram are you looking for? Your sig only says 82 firebird. What engine size? What type of induction?
Sorry feeling a little silly, it is Friday. Anyway CanadianCamaro your vacuum diagram is below.
Pac J
May 17, 2020 10:44 AM
