Cold start problems
Old Dec 14, 2005 | 10:23 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
Cold start problems
I have had this issue for quite some time since the HSR swap, but since the car is being sold, I want to get rid of it (it is the only thing holding this car back from being close to perfect). Anyways, when it is the first start of the day, it will start right up, but will die shortly after unless you press the gas and hold it up at a fairly high RPM (2500-3000 rpm) and let it warm up for a couple of minutes. After that, the car will run just great for the remainder of the day. The weird thing is that when gas is given in a quick manner, such as accelerating and revving it up high, it wants to die. This is only on the cold start. I checked codes and got codes for the MAP, EGR, temp sensor, and EST. Any suggestions as to what is causing this?
Old Dec 14, 2005 | 10:27 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Have you done any other modifications to the motor, and has the ECM been setup for it?
Old Dec 14, 2005 | 10:35 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Just HSR and exhaust. No internal modifications. I am still running a relatively stock tune. I've heard of people getting away with the stock tune with minimal problems, but of course is not the ideal set up. It is just odd that I am getting all of those codes and the car runs great when warmed up, but that first start of the day is real puzzling.
Old Dec 15, 2005 | 08:14 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Any ideas? I saw very similar problems posted before, but no real answers.
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
