oil pressure gauge question
Old Dec 15, 2005 | 04:32 PM
mantiz85ws6's Avatar
Car: 85 Trans Am
Engine: 350 T.P.I.
Transmission: WC T-5
What would cause an oil pressure gauge to peg on the high side when the key is just turned to the on position and once the engine is turned over it stays above 80 lbs and will not drop??
Old Dec 15, 2005 | 04:42 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
sending unit or the gauge itself.
Old Dec 15, 2005 | 04:45 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Check the wire on the oil pressure gage sender, sounds like it's grounding out on something
Old Dec 15, 2005 | 05:00 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
Thanks for the quick replies. I'm leaning towards the loose wire or grounded wire since I just had some work done to it and I found the cts wire not connected.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
R3500
Aug 17, 2015 12:16 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
