Bearing help
Old Dec 18, 2005 | 04:19 PM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Bearing help
I'm in the process of checking my main bearing clearances. The inside diameter is coming out between 2.4525" - 2.4530" on all 5. These are Fed-mog. 139M STD size. I'm using a dial bore gauge to check and I'm pretty confident in my measurements. The block was line-honed because I'm using studs and the empty bores are right on the money. They are consistantly on the large side, so I'm thinking I just got a bad set? Any other opinions? These seem way outa spec to me.
Next question (which might seem kinda of trivial): A 350 chevy has a nominal 2.450" journal size. When a bearing manuf. says "STD size" what should the final inside diameter be (dimensionally)? And what is the tolerance on std sizes? 2.45xx +/- 0.000x ??
Thanks.
Old Dec 18, 2005 | 05:09 PM
ede's Avatar
ede
off the top of my head the main diameter is 2.248-2.249 with no more than .003 oil clearance.
Old Dec 19, 2005 | 07:19 AM
Car: 1986 Iroc
Engine: Afr 408
Ede, my crank journals are within that spec, nice and round with no taper. I was thinking about it more last night and I think I might have torqued my caps incorrectly when I was test fitting. The studs call for 70 ftlbs with assembly lube or 80 ft lbs with 30wt. I think I mixed it up and only went 70 ftlbs with the 30wt. So I might not have had the bearing seated all the way. Also, I'm going to get a .001 undersize set to see if that helps.
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
