Chip Info
Old Dec 21, 2005 | 08:22 AM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Chip Info
What exactly would happen if i left my 160 thermostat in with my jet chip that asks for a 180?
Old Dec 21, 2005 | 10:06 AM
Vader's Avatar
There are several temperature dependent parameters in the ECM programming. You'll likely experience some operational problems, whether you realize/recognize them or not.
EGR function, EVAP function, cooling fans, fuel trims, Closed-Loop threshold, BLM writes, and several other functions depend on coolant temperature.
Old Dec 21, 2005 | 03:33 PM
Scheister's Avatar
Car: 85 IROC
how does a 160 effect a stock chip?
Old Dec 21, 2005 | 06:01 PM
Vader's Avatar
Here are some of the stock TPI ECM programmed parameters for coolant temperatures that might be affected by changing to a 160°F thermostat:
Open Loop Mode AFR % versus Coolant Temp - Threshold @ 154°F
Warm IAC Park Steps Vs. Coolant - Threshold @ 176°
LV8 Accel Enrichment Vs. Coolant - Threshold @ 176°
Accel enrichment Decay Factor Vs. Coolant - Threshold @ 176°
Idle RPM Vs. Coolant - Threshold @ 176°/154°
Rich/Lean Offset Vs. Coolant - Threshold @ 176°
Startup Spark Decay Delay Vs. Coolant - Threshold @ 176°
IAC Minimum Keep Alive Learning - Threshold @ 185°
Minimum CTS for Highway Fuel Mode - 185°
Hot Closed Loop Timer Threshold - 159°
Old Dec 21, 2005 | 06:07 PM
Vader's Avatar
And some other parameters related to coolant temperature:
Coolant Temperature Sensor Related Parameters
BLM enabled between 50°C (122°F) and 140°C (284°F)
Cold spark advance disabled above 56°C (133°F)
Hot spark retard begins above 116°C (240°F)
Highway Mode spark advance > 59.8°C (140°F)
Knock sensor disabled below 66.5°C (152°F)
Power enrichment at base A/F ratios > 56°C (133°F)
Target IAC idle RPM >80°C (176°F)
IAC multiplier at 1.0 (base) > 32°C (90°F)
Knock Control enabled > 67°C (153°F)
EGR Duty-cycle enabled at 56°C (133°F)
EGR Duty-cycle at MAX >80°C (176°F)
TCC lockup enabled >50°C (122°F)
SHIFT light enabled >50°C (122°F)
Diagnostic communication enabled at 70°C (157°F)
DTC 43 enabled > 90°C (194°F)
Cooling fan #1 enabled at 107°C (226°F)
Cooling fan #1 off at 104.7°C (220.5°F)
Cooling fan #2 enabled at 115.2°C (239.5°F)
Cooling fan #2 off at 110°C (230°F)
Cooling fan duty cycle at 100% at 80°C (176°F)
Acceleration enrichment multiplier at 1.00 below 80° C (176°F)
Acceleration enrichment multiplier at 0.75 above 80° C (176°F)
Acceleration enrichment multiplier at 0.50 above 104°C (220°F)
Acceleration enrichment decay factor at 25% below 80° C (176°F)
Acceleration enrichment decay factor at 40% above 80° C (176°F)
Acceleration enrichment decay factor at 50% above 104° C (220°F)
Acceleration enrichment decay factor at 60% above 128° C (262°F)
Fuel limiting factor timer at 217 counts below 80° C (176°F)
Fuel limiting factor timer at 169 counts above 80° C (176°F)
Code 13 (oxygen sensor fault) enabled above 70°C (157°F)
Code 14 (CTS high fault) enabled above 130°C (266°F)
Code 32 (EGR fault) enabled above 30.5°C (87°F)
EVAP canister purge enabled above 70.3°C (158.5°F)
Hot closed-loop timer enabled above 70.3°C (158.5°F)
Rich/Lean O2 offest at 16 counts between 20°C (68°F) and 92°C (197.5°F)
A/C clutch disabled above 150°C (302°F)
Old Dec 21, 2005 | 06:09 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
lol
Old Dec 21, 2005 | 07:27 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Lol, I think the old fasioned tbi ecms have like five of those things in them
Another thing to consider is the stock cooling system. It needs a good sized temperature differential to dissipate enough heat. What this means is that itll run at 160 in the winter, but will usually operate around 200 - 210 in the summer. I got tired of the constant luke warm heat in the winter and no benifits in the summer so I swapped a stock t-stat in and just run that. Runs at around 210 all year around.
Old Dec 21, 2005 | 07:34 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
The service engine light would most likely come on i bet.
Old Dec 21, 2005 | 08:16 PM
Vader's Avatar
It probably wouldn't set any error codes, but wouldn't be "right". It's fairly easy to properly reprogram the parameters to be able to use a lower temperature thermostat and still retain full functionality. All the steps are listed above.
Old Dec 22, 2005 | 04:03 AM
Scheister's Avatar
Car: 85 IROC
no it doesnt do that. my dad has had one in the car i curently have for years. i just havent had the chance to swap it out. i was just curious what it messes with
Fanatic1074
Oct 3, 2022 05:57 AM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Eric-86sc
Sep 28, 2015 11:37 AM
