Coolant leak hell
Old Dec 24, 2005 | 09:33 PM
85_Camaro_Kid's Avatar
Car: 1985 Chevy Camaro
Engine: 350 2-bolt
Axle/Gears: 10 bolt, 3.23 posi
Coolant leak hell
Okay, so my intake manifold was leaking.
Not a problem, I picked up a complete fel-pro gasket set for my 350 for $29 ater tax at Hot Rod barn. And I went to work. The next morning I eagerly woke up and started to fix my coolant leak. I started tearing into it with my freshly brewed coffee, and I noticed my bolts were only hand tight, and when I removed them I noticed all but two were missing the lock washers. (so the just rattled loose). So I walked my *** 4 miles to ace hardware and 4 miles back with 15 Lock washers. I ran RTV along the front and back ridges to keep it from leaking oil. I ran the bolts down with a hand socket driver, then went around it and torqued the nits to spec on the Intake manifold. I then set my ignition timing and played with the carborator. It fixed that!
Then I noticed I was still loosing coolant, so I traced that to a slit heater hose. I piced a new one up, and that fixed that!
So I am leak free! Or so I thought, I am driving down the road, enjoying my new found joy of of the tq in the Camaro, and POP! My radiator poped. Luckily I had my tools, and I coasteed into a autoparts store parking lot. I ploped down my $158.27 at advance auto parts, and installed my radiator there in the parking lot. 4 gallons a Prestone antifreeze, a bottle of Redlines wetter water, and distribuitor cap and rotor buttion (noticed mine was fried when I was doing the intake manifold gasket) later, I was back on the road going to see my upset girl friend (upset because I was late AND dirty). (Side Note: there is A WHOLE LOT OF POWER locked up in a fried Distribuitor cap and button, it felt like I just put headers and exhaust system or something on my car. )
That was 2 days ago, now today (Cristmas Eve), I noticed a coolant leak on to of my intake manifold AGAIN! Coolant is Gathering in the same exact nook of the intake manifold as before.
I am thinking that maybe the edlebrock intake manifold that is on it has warped do to running it for a day or 2 with coolant running low (HAD to go to work to be able to afford parts). The motor temp guage never reads HOT, it sets right where it should. 3/8 up.
What do you guys think? I keep telling myself that it is just warped, but I keep asking myself the question,"why did it hold for 3 days if it is warped?"
Any Ideas on my problems?
Old Dec 25, 2005 | 05:28 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
did you put any kind of sealant on the threads? i think a couple of them go into the water jacket. not sure on this though.
Old Dec 25, 2005 | 06:28 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
WAG, upper rad hose or thermostat housing leaking & running down onto the manifold.
Old Dec 25, 2005 | 07:07 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
maybe a pressure test is in order? just a thought
Old Dec 25, 2005 | 10:05 PM
Engine: 350 2-bolt
Wow, why didn't I think of this? Merry Christmas.
Old Dec 26, 2005 | 08:40 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Seen this before when using lock washers on the manifold bolts, oil will leak too. The factory used a sealing washer, looks like a lock washer without the cut. Check the thermostat and hose first then go after the bolts and washers. Antifreeze is sure aggravating sometimes.
Old Dec 26, 2005 | 12:37 PM
Engine: 350 2-bolt
The presure tuest turned up with with the intake manifold in the same spot. New intake manifold is on, let's see how long this holds.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
