will 1.6 r.tip crane clear my valve covers?
Old Dec 25, 2005 | 04:47 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
will 1.6 r.tip COMP rockers clear my valve covers?
I know I'll get the SEARCH thrown at me but I have so here`s my question.I got some 1.6 crane roller tip rockers from a friend of mine here in town for 75 bucks.I want to know if I need to get some bigger covers or will my stockers work for now.Any suggestions?
Old Dec 25, 2005 | 04:58 PM
DM91RS's Avatar
Car: 91 RS
I ran the Gold Cranes under the stock covers.......so yes.
The Comp Pro Mags will not however......
You will have to check for pushrod clearance in the head.
I had to clearance the Vortec's to clear.
Old Dec 25, 2005 | 05:00 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: will 1.6 r.tip crane clear my valve covers?
I had to go with tall valve covers when I went to 1.6 rockers. They are Scorpion brand tho. After also adding stud girdles I had to switch again to some Circle track covers.
Old Dec 26, 2005 | 10:38 AM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
How to mod your stock valve covers.
http://www.hotss.com/Members/scott_vaca/pro-mag.htm
Might help you out.
Old Dec 26, 2005 | 11:20 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
Might help you out.
Thats what I did.
Old Dec 26, 2005 | 12:28 PM
DM91RS's Avatar
Car: 91 RS
Good link Tier.........could save somebody on a budget some $$
Old Dec 27, 2005 | 09:05 AM
boogie's Avatar
How about Comp Cams roller tip magnum rockers in 1.52 ratio with stock centerbolt covers? Should be no problem,correct?
Old Dec 27, 2005 | 08:13 PM
jimp2001's Avatar
Engine: LO3 305 TBI
I have Summit full rollers, they are awesome
Old Dec 27, 2005 | 11:40 PM
well guys I made a goof, I don`t have crane rockers i have comp rockers.I didn`t see the insignia on the rockers them selves.
The pic is alittle blurry but it says comp cams on it.
Attached Thumbnails will 1.6 r.tip crane clear my valve covers?-100_4281.jpg
Old Dec 27, 2005 | 11:45 PM
one more thing I have noticed is that these are more narrow than the stockers quite a bit.
Attached Thumbnails will 1.6 r.tip crane clear my valve covers?-100_4276.jpg
Old Dec 28, 2005 | 07:23 PM
so does anybody think these will work with my stock covers?
Old Dec 28, 2005 | 07:46 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
With the mods done in the link I provided, they should be just fine.
Old Dec 29, 2005 | 08:24 PM
no offense but I don`t need a SHOULD WORK,I need a definative answer. Does anybody else run these who can tell me for sure?
Again I`m not trying to be a dick tier I just have to know if I should get taller covers or not.
Old Dec 29, 2005 | 09:30 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
Haha none taken, I just said should to cover my *** incase something doesn't work out which I doubt. I don't know the part number on those rockers, but I'm sure if the pro mags fit under the stock covers with just the mods than those shouldn't be any differen't. If need be you can call up comp cams and find out if there is a size difference in them.
Old Dec 30, 2005 | 12:09 AM
thanx for your help man
Old Dec 30, 2005 | 09:14 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I have crane 1.52 roller tips and they work just fine with stock covers. I suspect that 1.6 will not be much different.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
