Distributor Hold-Down Bolt?
Old Dec 28, 2005 | 03:27 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
I just got a Timing Light for christmas and decided I would try it out and check my timing.
I read the FAQ on how to set your timing, and I understand it all, but does anybody have any tips on how to get the distributor hold down bolt off? I can't squeeze any swivel joint socket/open end wrench/special tool in there because there is so much junk in the way. I am not having good luck working on this car, I get frustrated easily because everything is just built on top of everything else in this car.
Turns out my timing is 1 or 2+ retarded, can't really tell too well, so I need to advance it a little bit and people say "just put an open end wrench on it". Yeah right, I guess after you remove the TBI unit, manifold and everything else under the hood it's that easy.
And yes, the air cleaner is removed, somebody help me please!
Old Dec 28, 2005 | 03:50 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Spend $10, and get a dizzy wrench.
http://www.sears.com/sr/javasr/produ...&bidsite=CRAFT
Old Dec 28, 2005 | 03:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I hate to say it, but "just put an open end wrench on it" lol. That's how I get mine anyways. I guess it depends on the wrench, and it's length, as to how well it works. There is such a thing as a dizzy wrench - you could probably get at a parts store - it's angled and bent to get at that frustrating sucker.
I'm terrible at it myself, but a little patience goes a long way with a Chevy.
Old Dec 28, 2005 | 04:05 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
buy a dizzy wrench, they are 9.99$ at the store.
Old Dec 28, 2005 | 04:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
With the afore mentioned distributor wrenches you can loosen the hold down bolt without removing anything. You do not need to remove it. Just loosen it.
Old Dec 28, 2005 | 05:43 PM
WD92TA's Avatar
From: Pensacola NAS, Florida: Hometown Valparaiso, Indiana
Car: 1992 Trans Am
Engine: 305 TBI
I just did mine too, you have to use a tool that is like a open end wrench but its just the open end end and it goes on a half inch drive or extension socket. It might be a distributer bolt wrench like they say.
Old Dec 29, 2005 | 10:38 AM
Car: 1990 Camaro RS
Thank you so much everybody.
I was getting so frustrated with it, I had no idea they even made such a tool like that.
Again, thanks alot. I appreciate all the help.
Old Dec 30, 2005 | 10:44 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Sometimes its all about having the right tools for the job. Cheap Dist. wrench makes it easy.
Old Dec 30, 2005 | 11:02 AM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Yea, I just went to Autozone and picked up one for 5 bucks, worked great. (A lot easier than trying to use a socket or open-end wrench)
Frozer!!!
Jan 19, 2024 04:55 PM
mddaniel
Sep 8, 2015 05:16 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
