distributor problem?
Old Dec 26, 2005 | 12:16 PM
bigd25x's Avatar
Car: 92 Camaro RS TTops
Engine: V8 TBI
Transmission: th700-r4
ok i have a 92 camaro rs with the 305tbi. the other day i was driveing and it was chugging and stuff so i decided to replace the cap\rotor, well i got the cap off and the rotor was shot, then i notised the distributor can be moved by hand, does this just mean its loose? how do i go about adjusting it? i gotta redo the timeing correct? and set it at top dead center.
any information will help
Old Dec 26, 2005 | 04:25 PM
bigd25x's Avatar
Engine: V8 TBI
ok i got the cap and rotor in, and screweed down, i turn the distributor to the left all the way it idles at like 500rpms in park and has no power at all, i turn it to the right all the way it idles at 2000rpms, its at the center right now and its at a ruff 1000rpms in park and 700rpms in drive. which i think is still prety high...
Old Dec 26, 2005 | 04:26 PM
bigd25x's Avatar
Engine: V8 TBI
ps, whats the fireing order for my car, ne one have a diagram?
Old Dec 27, 2005 | 12:42 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
firing order is standard on sbcs, 1-8-4-3-6-5-7-2
you should set your timing to the correct spec for your car, if it's bone stock. something like 0*...?
Old Dec 27, 2005 | 04:03 PM
bigd25x's Avatar
Engine: V8 TBI
firing order is fine, the car starts np, but like it has no power now, at all. i dont know how to do timeing my syself and all my friends are busy. can anyone give me a little introduction on what to do. and no i cant aford a hanes manual right now and im selling the car ne ways. thx
Old Dec 27, 2005 | 04:33 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
look at the sticker on the hood, i believe tbi's you have to disconnect this 1 wire connector and set the timing, you need a timing light
Old Dec 28, 2005 | 01:06 PM
bigd25x's Avatar
Engine: V8 TBI
i know that, but how do you tighten it down. mines very loose right now
Old Dec 28, 2005 | 01:38 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
at the base of the dizzy there is a bolt 9/16 that holds down the clamp. on top of intake manifold.
disconnect wire thats out of harness above ac housing at passenger firewall to set timing.
Old Dec 28, 2005 | 02:00 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Old Dec 28, 2005 | 10:41 PM
bigd25x's Avatar
Engine: V8 TBI
im sory dialed in if your thinking im a idiot lol. i just never really got into igntions. ive done everything else, just never had to do a ignition before. now the nut your talking about, is it under the cap on the top of the distributor? right now i have it running good, i just wana tighten it down and get a light on it.
Old Dec 29, 2005 | 08:32 AM
SPIKE's Avatar
Car: 86 CAMARO
no its at the very base of the distributor, where it comes out of the intake manifold. the bolt holds a clamp attached to the manifold. look from passinger side. its a real pain in the *** to get to.
Old Dec 29, 2005 | 12:03 PM
bigd25x's Avatar
Engine: V8 TBI
ahh, thats explains A. why i couldent find it B. why it wasent tigtened down in the first place
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
