I got 3/8" bolts for my intake, they don't seem tight though
Old Dec 27, 2005 | 06:49 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I bolted on my Stealth Ram to my heads using 3/8" bolts as told and they are a hair smaller in diameter than the ones in there before. The 3/8" go in and grab, but I don't want to blow a gasket because they don't grab properly. Any ideas?
Old Dec 27, 2005 | 11:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that's a weird one.... do you have a caliper to double check the bolts you bought? (case they might be 10mm or something..?)
do you mean the bolt seems to be a bit 'loose' in the threads? perhaps the new 3/8" bolts you bought have a looser thread fit?
Old Dec 27, 2005 | 11:48 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
loose, are they all the way in and just dont tighten? maybe try and use a washer
Old Dec 28, 2005 | 12:10 AM
Car: 86 T/A
Engine: HSR 355
Loose as in it doesn't really feel as tight although its in its first few threads. Once its tightened down it feels tight, but its not the same size diameter as the previous bolt on there which concerns me. It is 3/8" though, fits in the header bolt holes perfectly as well.
Old Dec 28, 2005 | 10:57 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Is the thread size of the new bolts the same as the old bolts?
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Fronzizzle
Aug 9, 2015 01:15 PM
