Do I have a long or short water pump?
Old Dec 27, 2005 | 08:56 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
1987 Camaro IROCZ L98.
I measure about 7" from block to the circular mounting plate for the pulley. If I am measuring correctly, then according to March, I have a "long water pump". Can someone confirm?
I am looking to buy March Performance pulley set as a dress-up item.
Old Dec 27, 2005 | 09:17 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Almost all SBC's have long water pumps. Only the Corvette and i believe some if not all trucks had short. No thirdgen ever came with a short water pump.
Old Dec 27, 2005 | 11:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Short water pumps were phased out around 1970. Some car builders will still use an aftermarket short pump because of clearance issues but it only adds other problems. The short pump doesn't have mounting holes for the alternator or power steering pump so that requires even more modifications.
Now your next question is, is your water pump standard or reverse rotation?
Old Dec 28, 2005 | 10:36 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
The current water pump is an Edelbrock aluminum hi-flow unit, direct replacement as the factory unit. So, I assume (you know what people say about "assume") it is same rotation, the belt goes around same as factory.
FWIW: These are the March pieces that I think that I will order:
6170 set,,, crank 6171,,, water pump 6152,,, alternator 137,,, power steering 531.
How does this look?
One question I have for March is that my alternator drive belt is a 5 or 6 rib belt (very similar to a serpentine belt),,, their alternator pulley does not look like its machined for a 5 rib belt, it looks like a v-belt.
BTW: I have remove the air pump and the AC, therefore, I have only two belts.
Old Dec 29, 2005 | 08:31 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
long pumps were installed from factory 69-up in cars and 73-up in trucks
except for corvettes which i think kept the short pump a few more years into the 70s
and the ram horns exhausts too
Old Dec 29, 2005 | 10:32 PM
chesterfield's Avatar
Car: Pontiac
Short pump, 75-79 V8 Monza, Sunbird,Starfire ...Corvettes had short pump into the mid 80's, even with reverse rotation for serpentine belt.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
