Oil pressure gauge
Old Dec 29, 2005 | 03:40 PM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
Oil pressure gauge
I am wanting to mount a plain oil pressure gauge in the car this weekend. I want to leave the factory gauge hooked up also. Were will the new gauge sending unit/line tap into the motor are there extra oil jackets on the engine? Or maybe I was thinking can I somehow make a double connection where the sending unit screws into the block. Thanks or any help
Old Dec 29, 2005 | 04:39 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I use both gauges in my car and I just put a short nipple and a t block that allows both to be mounted into the stock location, works fine.. Hope this helps
Old Dec 29, 2005 | 04:46 PM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
Where can I get this t block and what size ?
Old Dec 29, 2005 | 05:38 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
If I remember right , it is a 1/8" pipe nipple and the t to fit it. You should be able to get it any local parts store. Talk to the sales person and explain what you need, they usually keep those items behind the counter to guard from theft. I thinks the hipple I used was 1-2" long. Look at the room you have at the back of the block near the distributor.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
