pick up coil question
Old Jan 2, 2006 | 03:01 PM
jeez's Avatar
Car: 1986 Chevy Camaro 2.8
Engine: 2.8 V6
i have a 86 2.8 camaro. it hasnt been starting for a while, but it cranks. if the pick up coil is gone bad will the engine still crank ?
Old Jan 2, 2006 | 03:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
As long as the starter works itll crank. The coil just generates a reference for the ign. module.
Old Jan 2, 2006 | 08:02 PM
jeez's Avatar
Engine: 2.8 V6
[QUOTE]Originally posted by dimented24x7
As long as the starter works itll crank. The coil just generates a reference for the ign. module. [/QUOTE
i was reading somewhere that 3rd gens have a history of bad pick up coils in the distributor, is this true ?
Old Jan 2, 2006 | 09:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
More or less the ignition module likes to fail when hot, from what I have noticed. Also more or less with V-8's.
But a part is a part and prone to failure all the same.
Old Jan 3, 2006 | 11:58 AM
jeez's Avatar
Engine: 2.8 V6
also i was wondering, if the pick up coil is gone bad, can thier still be spark ?? i am guessin not. see the car has spark, but i am not sure if it is enough or not ??, also fuel does come to the lines in the engine, again, not sure if thier is enough pressure..
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
