305 or 350?
Old Jan 3, 2006 | 02:33 AM
88 IROC CONVERT's Avatar
Car: 2002 zr2 Blazer 88 Iroc convertable
Engine: 305 T.P.I.
305 or 350?
if you have one of each on the floor how can you tell them apart?
Old Jan 3, 2006 | 03:12 AM
CrazyHawaiian's Avatar
Car: too many ...
Look on the castings on the block on the back side (flex plate side). It will read 5.7 (means 350) or 5.0 (means 305). If you wanted to go even further get all the numbers on the block and by searching you can find out exactly what kind of block it is. There are alot of different generation 1 small block chevy engine blocks, but for us F-body guys I think the big change was in 87 for hyd roller cam setup.
Old Jan 3, 2006 | 11:12 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Not all blocks are going to have the displacement stampings.
All blocks will, however, have the casting number, and that will tell you.
Old Jan 3, 2006 | 01:54 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If the motors have the heads off you can just measure the bores. Under 4" = 305 over 4" = 350. However, not all 4" bore motors are 350's. That is where the casting numbers come into play.
www.mortec.com
Old Jan 4, 2006 | 12:54 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Or if theres to much in the way to see the casting numbers on the back of the block, jack up the front of the car, look on the driver side of the bottom/front of the block and you will see 3 numbers; 638 or 627. Hope you have 638
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
