porting / polishing tools needed
Old Jan 3, 2006 | 04:33 PM
nosvet's Avatar
Has anyone in the group had experience with DIY porting and polishing? I'm looking for some guidence on a good tool kit for each task and any pointers.
Chris
Old Jan 3, 2006 | 06:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
do a search. You'll read sitting bulls post, he has mentioned some tools.
off the top of my head:
die grinder, recommend electric with speed controller
3" and 6" long carbide burrs, tree or flame style. maybe a cylinder one too
mandrel for sanding drums
tapered sanding drums (mucho)
cross buffs, and mandrel for that.
That's basically all you need.
Old Jan 4, 2006 | 10:38 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Don't forget Earplugs.
It is always nice to find a cheap, junk set of heads for you to get the feel of your tools and grinding on cylinder heads. When I went to port my heads it made me feel a lot more comfortable.
Old Jan 4, 2006 | 11:08 AM
Sonix's Avatar
Car: 1982 Trans-Am
yea, for sure, and goggles. A shop vac would be needed sooner or later too (usually have one of those around), and good lighting.
I had some 993 heads, that I went at first. I didn't finish them, as they were just practice, but it showed me how the bits cut, etc.
Also think about what you'll be doing with the rocker studs too, if these are stock heads.
IROCZ1989
Jan 24, 2016 03:55 PM
kah992
Aug 19, 2015 02:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
