Camaro Wants To Die
Old Jan 4, 2006 | 10:00 PM
todda's Avatar
Car: 92 CAMARO
Engine: 5.0
Camaro Wants To Die
HELP! I HAVE A 92 CAMARO WITH A TBI 305, AUTO. IT STARTS FINE , IDLES FINE, SOUNDS GREAT BUT AS SOON AS I PUT IT IN GEAR IT DIES. BACK IN PARK,START UP, RUNS GOOD PUT IN DRIVE AND DIES. I CAN KEEP MY FOOT ON THE GAS AND SHIFT INTO DRIVE AND IT WILL GO BUT LACKS POWER. AS SOON AS I BRING IT TO A STOP IT WILL DIE IF I LET OFF THE GAS.
ANY HELP WOULD BE APPRECIATED.
THANKS
Old Jan 4, 2006 | 10:32 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Maybe a vacuum leak.
Start looking right around your caps-lock key.
Old Jan 4, 2006 | 11:04 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That darn caps locks booster valve must be stuck again (avoid typing in caps locks).
Could be a vacuum leak, as mentioned. If that were the case, though, it wouldn't idle so well. What is the idle speed in park?
How does it drive normally, once you get it going? Does it have any hesitation (signaling that there might not be enough fuel to feed the engine under load)? A fuel pressure tester might be worth looking into.
If it runs fine otherwise, something perhaps an ill-functioning torque converter could cause it.
Old Jan 5, 2006 | 12:29 AM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
Have you checked your timing on the car. Check the vacuum line going to the brake booster also.
Dan
jklein337
Sep 19, 2018 06:23 PM
pimp2303
Jul 27, 2017 02:03 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
legendaryhero7
Aug 12, 2015 06:19 PM
