Connecting rod question
Old Jan 6, 2006 | 11:09 AM
inuyasha_lost's Avatar
Car: 92 Camaro RS 25th Anniv
Engine: 93 LT1 w/Vette Access
Axle/Gears: 97 T/A w/3.42 posi
Hey gang, i am in a rush today so i can't browse for this question. I am rebuilding my 305, i added 350 heads, turned the crank (.010), new pistons, cam (for computer control), but the push rods are my question. the wrist pins are press fit into the piston, do i need a press fit connecting rod or a floating. Next question would be could i go to a 6.00 instead of the stock 5.7 lenght?
Old Jan 6, 2006 | 11:21 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Press fit. I think you mean connecting rod instead of pushrod you described. Also u use a lengh rod that your pistons are made for whether its a 5.7 or 6. Cant do both.
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Press fit piston needs a press fit rod. Floating rods require floating piston, floating pistons have provisions for snap rings.
No you can not upgrade to 6 in rods with 5.7 in pistons unless you exchange your pistons for 6 in rod pistons.
Make sure you have enough compression with those 350 heads, you may need domed pistons. 5.7 is just fine for a mild engine running low RPMs (less then 6500). Just make sure the rods are checked (magnaflux), peened, and have ARP bolts.
Old Jan 6, 2006 | 10:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Don't use iron 350 heads on your 305, you will kill the compression because of the larger chamber and lose power.
Get a set of 305 HO heads (#416, 601) or get some 305 TPI heads (#081). The ONLY 350 heads you should use are the Corvette aluminum ones from the late '80s, because they have the same small chamber size as the 305 heads.
Old Jan 6, 2006 | 10:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
There are plenty of 350 heads that are a step backward in performace and a few that are actually semi decent.
What heads particularly did you use?
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Reborn756
Sep 4, 2015 03:42 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
