dieseling
Old Jan 6, 2006 | 08:46 PM
supercrossman's Avatar
Car: 86' TA
dieseling
I have a really wierd problem, I dont know if its always done it but I noticed it did it last time. It doesnt usually keep going after I shut the car off (dieseling) but it did it the last time I shut the car off and the accessories stayed on like the heater fan. It would kinda go in and out when the motor would start to die it would go off when the motor picked back up a lil again it would come back on. what in the hell could cause this?
Old Jan 6, 2006 | 09:01 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Check your electrical connections.... Computer controlled quadrajet? My buddy's 84 T/A with an L69 CC Q-jet had a bad dieseling problem and it turned out to be a loose electrical connection to the carb
Old Jan 6, 2006 | 09:04 PM
Car: 86' TA
yea its a computer controlled quadrajet I have the top sensor unplugged im not sure what it does but it runs like **** with it plugged in, I have to pump the gas to make it even move with it plugged in but when its unplugged it runs alright. It doesnt diesel very often but im wondering what the hell would cause the heater fan to come back on when it was doing it
Old Jan 6, 2006 | 10:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Whats your idle speed? If its too high, it can cause run-on (dieseling). So can an overly lean mixture or too much spark advance.
Old Jan 6, 2006 | 10:47 PM
Car: 86' TA
no the idle speed is fine in gear its around 500 outa gear its around 1k. More then the dieseling which I beileve to be caused by it was overheated. more of what im worried about is the accesories being on when its doin it when the ignition is off
Old Jan 6, 2006 | 10:49 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
It doesn't sound like true dieseling to me, but more electrical.
I suggest you get the carb fixed properly so it actually runs as it should.
As for the power staying on, I've seen a bad ignition switch in the column do that, and I've seen a failed alternator diode do that.
Old Jan 6, 2006 | 11:02 PM
Car: 86' TA
well I would like to get the carb fixed but I have no idea what the problem with it is.
school boy
Oct 22, 2015 11:47 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
MoonDog
Jun 14, 2002 12:37 AM
86Trans Am
May 12, 2001 02:10 AM
