A possible crankcase leak
Old Jan 7, 2006 | 06:48 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
I believe the idling problem I have been having may be due to a crankcase leak between the intake manifold and the block. How would I test this? Would plugging both PCV holes and checking for improvement be an affective way?
Old Jan 8, 2006 | 02:30 AM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Hook up a smoke test
Old Jan 8, 2006 | 08:50 AM
joe350's Avatar
Car: 91 Z28
Where would I get a smoke test machine?
Old Jan 8, 2006 | 12:47 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
A leak between the intake and the block won't cause a perf problem. It will leak oil however.
If you mean a leak between the intake and the heads, that can cause an "internal vacuum leak". You can check for that by plugging the pcv hole and the breather hole on the other valve cover; start eng and check for vacuum building in the crankcase.
I've done this test using the palms of my hand to plug off the pcv valve and breather holes. It's a lot more comfortable on a cold eng.
Pac J
May 17, 2020 10:44 AM
RS Reaper
Oct 17, 2018 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
