Stock Lifters?
Old Jan 8, 2006 | 08:27 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Stock Lifters?
Hey guys, I'm going to be rebuilding an engine with just new rings and bearings and such, but was wondering if the rumor i heard is true, that if you put the lifters in different bores then the ones the came in it will cause premature wear. What are the accepted clearances in them. I can mic out all of the lifters and bores but that would be somewhat time consuming, but maybe time well spent.Thanks guys.
Since I'm posting I figured I should ask what heads are better for porting, i've got a set of 882's i heard are junk and a set of 441's which came stock on 69' 350's with 255hp. I know neither of them are great for performance but i just need to get my camaro moving again.
Old Jan 8, 2006 | 10:30 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The lifters have a specific wear pattern with the cam lobe they were on, and each is unique. If you swap them, they don't "match" anymore, and they can accelerate cam wear.
Genopsyde
Oct 7, 2015 08:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
