Dumb connecting rod question
Old Jan 9, 2006 | 10:15 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
In a LO3, why can't one use 6.0 rods or longer with the stock pistons (for the stock 5.7 rods) ?
Old Jan 9, 2006 | 10:53 PM
Guest
Guest
Posts: n/a
You can, just gotta move the head out of the way.
There's only so much space from the crank centerline to the top of the deck/head mounting surface. Add in 1/2 the stroke, rod length, piston height... better be close to that number and not much over it or the cylinder head and bolts are going to be unhappy with your bottom end and fight back.
Old Jan 9, 2006 | 11:14 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
So it's an "alignment" thing ? Just trying to picture it
Old Jan 9, 2006 | 11:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's not an alignment thing, it's a physical impossibility thing. If you make the rod 0.3" longer, the piston has to move up in the bore by the same mount. Since there's only about .025" between the top of the piston and the deck surface on an unmolested block, the pistons would be sticking up about .275" above the deck.
If you want to use a rod .3" longer than the stock 5.7", you need to use a piston that has its wrist pin .3" higher than stock.
Old Jan 9, 2006 | 11:27 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
OK yeah I didn't have the actual figures in my head. I just thought hey longer rod, would result in higher compression.
Old Jan 9, 2006 | 11:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It would, if you had some kind of hugenormous combustion chamber that would let you bring the pistons up that high without hitting the heads.
Old Jan 10, 2006 | 12:24 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The day where combustion chambers are measured in cubic inches....
Old Jan 10, 2006 | 12:38 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
My combustion chambers are 4.4 cubic inches, what are yours?
BRoss99
Aug 10, 2025 05:08 PM
Reborn756
Sep 4, 2015 03:42 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
