ZZ4 cam in an LT1
Old Jan 10, 2006 | 06:29 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
Engine: 383cid, 350cid
Transmission: 4L60, NV3500
Axle/Gears: 3.73, 4.10
ZZ4 cam in an LT1
Anyone use this combo? It's a 94 LT1, will the stock computer run it ok?
Old Jan 10, 2006 | 06:36 PM
Damon's Avatar
Haven't tried it but.... on a 94 LT-1 the Optispark is driven via a splined shaft that goes into the nose of the cam, or maybe it's just the top timing chain gear...... I wonder if that would cause a compatibility problem somehow, just physically bolting it all together.
I'm sure somebody will chime in here.
Old Jan 10, 2006 | 09:05 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
I think I just need to put in a dowel pin. It's got the hole for it. Anyone know for sure?
Old Jan 11, 2006 | 04:06 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
ttt?
Old Jan 11, 2006 | 05:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The non-vented opti's (93-94) are driven off the splined shaft, yes. Vented (95-up) systems are driven off the cam pin, IIRC.
In order for the cam to work with Opti, a machine shop would have to drill out the nose of the cam to fit the opti drive system (again, IIRC - but am 98% certain).
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
