AC delete box?
Old Jan 15, 2006 | 04:09 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
AC delete box?
Ok, I bought me an AC delete box and Im going to take my AC completly out...where in the hell do I even start to attempt to take the old AC box out? is this an easy task?...and also once I get the new box in....my heat will still work, right?
Old Jan 15, 2006 | 11:14 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
remove ac accumulator
remove upper half of ac box
remove lower half of ac box
remove ac evaporator core (inside box)
remove blower motor from old box and install on new box
install new box to firewall
I do belive you are going to have a large hole in the firewall that the ac delete box will not cover. You will either have to weld a plate or attach a piece of metal with some sheet metal screws to cover the hole.
This is a very basic version of how to do it but it will get the idea across.
Old Jan 15, 2006 | 11:44 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The box will cover everything. You will not have any holes. For the box I would remove all the 10MM bolts holding it on from around the outside. THEN. You have to go in the car under the dash and remvove the 2 10mm bolts holding it on from inside behind the carpet by the by the passengers feet.
Old Jan 15, 2006 | 11:55 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I just removed mine. It took less than 15 min. and I was surprised how easy it was. Just follow what Mkos1980 said. Instead of an A/C delete box, I used sheet metal and some caulking to seal it up. It's functional, but if you are going for looks, you might still want the box.
Old Jan 16, 2006 | 01:50 AM
llvll4l2c91350's Avatar
Re: AC delete box?
is the A/C working? if yes, i would just leave it. i regret very much taking mine out.
btw the A/C blower fan is too big for the delete box. u'll have to get a shorter fan from another GM product.
Old Jan 16, 2006 | 06:00 AM
Re: Re: AC delete box?
I havent had AC in the car for the last couple of years...it did work fine but when I did all the other work on the engine I took off the AC motor and lines and was left with what you see...yeah sometimes I wish I had AC but oh well.....I just want to remove whats left....the delete box I got off EBAY comes complete with working motor and resistor....so I wont have a problem with the fan size.....
I just want to have as much room as I can....cause sometimes I have to tighten the header bolts and with the box out of the way I have alot more room...
I figured this isnt a luxury car so I will just have to deal with it...LOL
Old Jan 19, 2006 | 02:57 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I just shaved my fan.. with a metal cutter ahahaha I will post of pics later of my whole process...
Old Sep 25, 2006 | 08:53 PM
Need help wiring it!?
yeah Im bring back my own thread back from the dead....I finally got around to taking out the old and putting in the new....
and I havent a clue what to wire to where...anyone help me out?
heres the wires I have coming off the new one..only 3
Old Sep 25, 2006 | 08:55 PM
and heres the cluster f*** of wires I have that where connected to the old AC/heater box...
what do I cut and wire to the 3 new wires
from looking at it..it looks like I dont need most of the old wires anymore...
thanks
Old Sep 26, 2006 | 11:36 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I fab'ed up a half inch spacer to go between the fan motor and the heater box and got some longer screws from Lowes.
83 Crossfire TA
Sep 18, 2015 12:01 PM
buckshot63
Sep 10, 2015 09:15 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
