TPI to carb distributor question
Old Jan 18, 2006 | 10:37 PM
rjs04's Avatar
Car: 1986 IROC, Shaved andBagged S-10
Engine: modded 355
I have searched for this but cant really find a clear answer to it. My car is an 86 Iroc that originally had TPI on it, when i got the car it looked like the wiring had been on fire and someone had put a carb on it (I didnt care because i was taking the original 305 out for a carbed 355). So i put the motor in and its starting up but i read about using computer controlled distributors with carbs and that i need a vaccum advance one, i just want everything to be right before i get the car on the road. It has a delco remy dist. on it right now. So should i switch it out for a vaccum advance one before i run into any problems. I was going to just get a msd cap and blaster coil for it but then i read about the vaccum stuff and decided it might be a good idea to get a different dist. Thanks for any help guys.
Old Jan 18, 2006 | 10:39 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yes, you need the vacuum advance type setup. You can still use the MSD cap and rotor and whatnot, you just need the vacuum advance canister.
Old Jan 19, 2006 | 01:01 PM
rjs04's Avatar
Engine: modded 355
So i need to get a new dist. really. Another question is if i am going to run nitrous and a timing retard how would that work with a vac. dist.
Old Jan 19, 2006 | 01:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No problem.
Old Jan 19, 2006 | 02:17 PM
rjs04's Avatar
Engine: modded 355
I called jegs today and the guy on the phone said that i dont need a vac. advace if i get the pro billet dist. he said that it had mechanical advance in it so i think i am just going to get the sb chevy ignition kit from there with the Dist., 6al box, coil and wires. I think that would be the best route for me to take because i want a 6al box and i need a coil anyway so i might as well go ahead and get the good stuff. If anyone sees anything that i am screwing up on let me know. Thanks.
Old Jan 19, 2006 | 02:22 PM
five7kid's Avatar
The Digital 6 box has the retard capability built into it.
I would still get a distributor with vacuum advance. If the one you're looking at has it, fine.
Old Jan 19, 2006 | 08:33 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I also vote for a vacuum advance dist. It was my impression that the vacuum advance improved fuel economy, and made for easier starts. Is that correct?
Old Jan 20, 2006 | 09:58 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
mostly better fuel economy. if you don't run vacuum advance, when cruising, you'll have like 30ish* rather then 50*ish degrees, so your mileage drops, and your plugs load up quicker.
Read the article on the main page of TGO, written by damon, about HEI timing, good info there.
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
